How Spray painting works
Simulate and test your painting on your PC. SprutCAM Robot will give you all you need for it.
- Generate a toolpath for spray painting
- Simulate and verify it
- Edit the toolpath interactively if necessary
- Start your robot with the G-code obtained
Use different Spray tools
A broad range of spray tools allows you to create various spray patterns.
Use different Robots
SprutCAM Robot has a comprehensive library of 3D models and postprocessors for robots
Main features
for a productive workflow
Main features
Simulation in real time
In SprutCAM Robot you work with a 3D model of your robot cell. Because it’s convenient and visual.
Our library has more than 300 models of robots usable out of the box.
You can build your robot cell in our special app – MachineMaiker 2.0
Main features
Control paintwork thickness
Painting simulation allows you to visualize the areas of the parts that will be painted as well as control the thickness of the paintwork (depending on the chosen type of painting).
Main features
Full painting process control
SprutCAM Robot has an array of tools and settings to create a safe and high-quality painting job
- Coating thickness control
- Adjustible spray cone size
- Control of the movement of the robot’s axes
