MOTOMAN MPX2600
MOTOMAN MPX2600 specs:
Brand MOTOMAN
Model MPX2600
Payload 15 kg
Reach 2000 mm
Repeatability 0.2 mm
Weight 485 kg
Start programming MOTOMAN MPX2600
MOTOMAN MPX2600 | SprutCAM X
MOTOMAN MPX2600 description
Watch MOTOMAN MPX2600 in 3D
MOTOMAN MPX2600 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot MOTOMAN MPX2600 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Robot welding, Painting, Spraying, Pick and place. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how MOTOMAN MPX2600 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
MOTOMAN MPX2600 applications programmed with SprutCAM X Robot
Spraying
How to start programming MOTOMAN MPX2600 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including MOTOMAN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the MOTOMAN MPX2600, please contact the manufacturer or local supplier.
If you have questions about purchasing the MOTOMAN MPX2600, please contact the manufacturer or local supplier.
