Kuka KR 140 comp
Kuka KR 140 comp specs:
Start programming Kuka KR 140 comp
Kuka KR 140 comp | SprutCAM X
Kuka KR 140 comp description
Watch Kuka KR 140 comp in 3D
Kuka KR 140 comp applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot Kuka KR 140 comp can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Trimming, Robot welding. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how Kuka KR 140 comp can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
Kuka KR 140 comp applications programmed with SprutCAM X Robot
How to start programming Kuka KR 140 comp with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the Kuka KR 140 comp, please contact the manufacturer or local supplier.
If you have questions about purchasing the Kuka KR 140 comp, please contact the manufacturer or local supplier.
