SIASUN GCR20-1400
SIASUN GCR20-1400 specs:
Brand SIASUN
Model GCR20-1400
Payload 20 kg
Reach 1400 mm
Repeatability 0.05 mm
Weight 66 kg
Start programming SIASUN GCR20-1400
SIASUN GCR20-1400 | SprutCAM X
SIASUN GCR20-1400 description
Watch SIASUN GCR20-1400 in 3D
SIASUN GCR20-1400 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot SIASUN GCR20-1400 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Robot welding, Pick and place, Assembly. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how SIASUN GCR20-1400 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
SIASUN GCR20-1400 applications programmed with SprutCAM X Robot
How to start programming SIASUN GCR20-1400 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including SIASUN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the SIASUN GCR20-1400, please contact the manufacturer or local supplier.
If you have questions about purchasing the SIASUN GCR20-1400, please contact the manufacturer or local supplier.
