ROKAE NB4h-4_0.58
ROKAE NB4h-4_0.58 specs:
Brand ROKAE
Model NB4h-4_0.58
Payload 4 kg
Reach 580 mm
Repeatability 0.02 mm
Weight 22 kg
Start programming ROKAE NB4h-4_0.58
ROKAE NB4h-4_0.58 | SprutCAM X
ROKAE NB4h-4_0.58 description
Watch ROKAE NB4h-4_0.58 in 3D
ROKAE NB4h-4_0.58 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ROKAE NB4h-4_0.58 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Trimming, Deburring, Painting. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE NB4h-4_0.58 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE NB4h-4_0.58 applications programmed with SprutCAM X Robot
Spraying
How to start programming ROKAE NB4h-4_0.58 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including ROKAE. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the ROKAE NB4h-4_0.58, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE NB4h-4_0.58, please contact the manufacturer or local supplier.
