KUKA iiwa7 R800 - MF IO elektrisch
KUKA iiwa7 R800 - MF IO elektrisch specs:
| Type | Cobot |
| Brand | KUKA |
| Model | iiwa7 R800 - MF IO elektrisch |
| Axes | 7 |
| Payload | 7 kg |
| Reach | 800 mm |
| Repeatability | 0.1 mm |
| Weight | 23.9 kg |
KUKA iiwa7 R800 – MF IO elektrisch description
KUKA iiwa7 R800 – MF IO elektrisch applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot KUKA iiwa7 R800 - MF IO elektrisch can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Trimming, Deburring, Pick and place, Assembly. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how KUKA iiwa7 R800 – MF IO elektrisch can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KUKA iiwa7 R800 – MF IO elektrisch applications programmed with SprutCAM X Robot
How to start programming KUKA iiwa7 R800 - MF IO elektrisch with SprutCAM X Robot
