SprutCAM X 16 is Now Released
SprutCAM X 16 is Now Released | SprutCAM XMay 3, 2022
May 3, 2022 (Limassol, Cyprus) – SprutCAM Tech, LTD., developer of SprutCAM X, the world’s leading unified CAD/CAM environment for Industrial Robots and CNC Machines, announces the global release of SprutCAM X 16.
Version X 16 is a substantial release introducing many new features in all areas of the product including a clean redesigned UI; new Solid Simulation; updated Smart Hints; advanced CAD Editor; new Probing group of operations; Swiss-type Machines, U-axis turning and Painting Robots support. In addition, the latest version of SprutCAM X offers improvements in Welding, Wire EDM, MachineMaker and much more.
Interface
We paid more attention to detail and stability; a brand-new high-tech style of the main window allows users to work even smoother and faster.
Tooltips have become interactive, they now clearly show where and how the operation parameters are used, so we called them Smart Hints.
New interface SprutCAM X
Solid Simulation
Advanced Solid simulation technology shows the result of machining with greater accuracy compared to voxel type simulation.
This is especially noticeable for large parts with small elements.
Swiss Machining
Now SprutCAM X supports Swiss-type CNC turning centers: programming, cycle time optimization, and full machine and process simulation.
The system provides automatic transformation of a sequence of linear operations into a cyclic parallel program. It includes the automatic operations reordering and the sync points placement.
U-axis turning
U-axis turning makes it possible to machine large, unbalanced parts like valve bodies in a single, continuous cut, with the workpiece clamped in place.
On such machines the workpiece is stationary, and the tool is rotated. U-axis is used to change the machining radius.
New operation: probing
The new SprutCAM X 16 release offers a powerful suite of probing cycles that combine machining and inspection into one complete NC program.
Now you can use the following cycles: single surface, hole/boss, groove/web, internal/external, internal/external corner probing.
New operation: welding
New welding operations have been introduced in the system. The Welding 6D operation provides Seam, Stitch, Tack and Spot welding.
New Point Welding operation can be used to Tack weld and Spot weld. Points can be moved by dragging and used to build a chain of trajectories. It is also possible to rotate the tool axis in 6D by dragging the visual vector.
New operation: painting
CAD updates
Dozens of improvements have been made to the SprutCAM X CAD module: improved stability and performance, new sketching tools, significantly updated Extrude and Revolve operation.
You can snap to points and faces of existing geometry while sketching or dragging surfaces. We have added a visibility control panel for SprutCAM objects: 3D Model, Part, Machine, etc. The user can now import curves, edges, and faces from the 3D Model into a sketch.
MachineMaker updates
With robots and mechanisms online library you can explore 300+ ready robots, positioners, and other mechanisms. The updated MachineMaker now allows you to assemble a Digital Twin of any 3-axis milling machine, and a new interactive 3D Model Simplifier enables users to remove inner faces and small objects from any 3D Model.
MachineMaker it the tool for assembly robot cells and CNC machines cells
New Cutting Tools Import API
Using Cutting Tools Import API now you can write your own programs to import cutting tools into the SprutCAM X from external TDM/PDM/PLM systems. It lets you create new turning, milling, and other custom tools by specifying your own geometric dimensions and properties and then saving them to a library file.
Share this story
Related Posts
Subscribe
Notify of
0 Comments
Inline Feedbacks
View all comments
