ESTUN ER30-1810-F
ESTUN ER30-1810-F specs:
Type Industrial Robot
Brand ESTUN
Model ER30-1810-F
Axes 6
Payload 30 kg
Reach 1810 mm
Repeatability 0.04 mm
Weight 284 kg
Start programming ESTUN ER30-1810-F
ESTUN ER30-1810-F | SprutCAM X
ESTUN ER30-1810-F description
Watch ESTUN ER30-1810-F in 3D
ESTUN ER30-1810-F applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ESTUN ER30-1810-F can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Machine Tending. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ESTUN ER30-1810-F can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ESTUN ER30-1810-F applications programmed with SprutCAM X Robot
How to start programming ESTUN ER30-1810-F with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including ESTUN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the ESTUN ER30-1810-F, please contact the manufacturer or local supplier.
If you have questions about purchasing the ESTUN ER30-1810-F, please contact the manufacturer or local supplier.
