ESTUN ER220-3100-P
ESTUN ER220-3100-P specs:
Type Industrial Robot
Brand ESTUN
Model ER220-3100-P
Axes 6
Payload 220 kg
Reach 3100 mm
Repeatability 0.06 mm
Weight 1345 kg
Start programming ESTUN ER220-3100-P
ESTUN ER220-3100-P | SprutCAM X
ESTUN ER220-3100-P description
Watch ESTUN ER220-3100-P in 3D
ESTUN ER220-3100-P applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ESTUN ER220-3100-P can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Pick and place, Assembly, Robot welding, Painting. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ESTUN ER220-3100-P can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ESTUN ER220-3100-P applications programmed with SprutCAM X Robot
Spraying
How to start programming ESTUN ER220-3100-P with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including ESTUN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the ESTUN ER220-3100-P, please contact the manufacturer or local supplier.
If you have questions about purchasing the ESTUN ER220-3100-P, please contact the manufacturer or local supplier.
