CHAIFU SF6-C1400XWeld
CHAIFU SF6-C1400XWeld specs:
Type Industrial Robot
Brand CHAIFU
Model SF6-C1400XWeld
Axes 6
Payload 6 kg
Reach 1440 mm
Repeatability 0.05 mm
Weight 150 kg
Start programming CHAIFU SF6-C1400XWeld
CHAIFU SF6-C1400XWeld | SprutCAM X
CHAIFU SF6-C1400XWeld description
Watch CHAIFU SF6-C1400XWeld in 3D
CHAIFU SF6-C1400XWeld applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot CHAIFU SF6-C1400XWeld can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot welding, Trimming, Deburring, Machine Tending, Assembly. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how CHAIFU SF6-C1400XWeld can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
CHAIFU SF6-C1400XWeld applications programmed with SprutCAM X Robot
How to start programming CHAIFU SF6-C1400XWeld with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including CHAIFU. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the CHAIFU SF6-C1400XWeld, please contact the manufacturer or local supplier.
If you have questions about purchasing the CHAIFU SF6-C1400XWeld, please contact the manufacturer or local supplier.
