CHAIFU SF50-C2185
CHAIFU SF50-C2185 specs:
Type Industrial Robot
Brand CHAIFU
Model SF50-C2185
Axes 6
Payload 50 kg
Reach 2185 mm
Repeatability 0.08 mm
Weight 550 kg
Start programming CHAIFU SF50-C2185
CHAIFU SF50-C2185 | SprutCAM X
CHAIFU SF50-C2185 description
Watch CHAIFU SF50-C2185 in 3D
CHAIFU SF50-C2185 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot CHAIFU SF50-C2185 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how CHAIFU SF50-C2185 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
CHAIFU SF50-C2185 applications programmed with SprutCAM X Robot
Polishing
How to start programming CHAIFU SF50-C2185 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including CHAIFU. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the CHAIFU SF50-C2185, please contact the manufacturer or local supplier.
If you have questions about purchasing the CHAIFU SF50-C2185, please contact the manufacturer or local supplier.
