Experience the innovative all-in-one software suite for complex and creative robotics tasks
SprutCAM X Robot: innovative all-in-one CAD/CAM/OLP for robots
Get a quote Download trial
MeetSprutCAM X Robot
- Model tab is for 3D model design, import and transformation
- Machining tab is for creation of technological sequence. 80% of job is done here
- Simulation speaks for itself
Inspector is the place there all the technology parameters are defined: job zone, toolpath strategy, tolerance, interpolation, approach and retract, links, feeds and speeds, toolpath transformation etc
Machining operations sequence
Useful tools for everyday work: virtual machine pendant, tape measure, postprocessor, machining report, tool management, verify and compare tool, tool reach inspector, axes graph and 3d model transformation tools.
Gain full control over singularities, collisions, reach zone limits, and redundant degree of freedom provided by 6th axis using a dedicated and powerful tool: the robot axis map
Precise and smooth simulation of workpiece evolution through the machining process. Either for machining or for additive processes
The main working area. Here are machine digital twin, part, workpiece, tools are shown. SprutCAM X Robot shows the interactive elements and simulation in this area
Go beyond
traditional robot simulation software
SprutCAM X is an all-in-one solution for offline
programming that includes:
Toolpath calculation for any application
Simulation
Optimization for singularity and collision free movements
Post-processing
Offline robot programming workflow
CAD
CAD
Design with integrated CAD or import 3D models
CAM
CAM
Generate toolpath
Generate the optimal toolpaths for robotic milling coming from the advanced CAM software, SprutCAM X, customized for robots. As well as robot-specific toolpaths.
OLP
OLP
Manage robot kinematics
Handle singularities, collisions, reach zone limits and control redundant axes movements with dedicated tools
Simulation with Digital Twin
Simulate a robotic cell of any complexity with high resolution and smoothness
Post-processing
Post-processing
Generic and tailor-made postprocessors
Pre-Launch Verification
Leverage the power of G-code verification
MachineMaker: zero code digital twin builder
SprutCAM X Robot allows manufacturers and integrators to create an accurate real-world cell with equipment and production components in a virtual environment, as well as simulate all robot functions on the screen.
The quality of simulation and detailing of digital twins in SprutCAM X Robot is second to none.
A wide range of certified post processors for most makes and models of robots guarantee error-free code. SprutCAM X Robot library of kinematic diagrams supports the largest selection of industrial robot brands. And with the MachineMaker app, you can quickly create an accurate kinematic model of any robotic cell.
Supported machinery
Industrial robots
Heavy-Duty
Robots
Cobots
End effectors
Rails
Rotary tables
Stationary objects
Applications
Take advantage of offline robot programming:
Go beyond traditional simple applications such as pick-and-place.
Discover new possibilities with enhanced milling, multiaxis cutting, additive and hybrid manufacturing technologies.
3—5D milling with redundant axes support
Robot cutting
Multiaxis cutting with precise tool vector control
Additive
3—5D cladding with advanced layer thickness control
Robot welding
Simple easy-to-use solution for welding programming
Sculpture/Stone
Stone roughing, disk tool, advanced 5D finishing for mesh models
Collision-free automatic pick-and-place
Spray painting
Simulate and test your painting on your PC
Polishing
Tool-to-part and part-to-tool supported
Technology highlight:
additive and hybrid
Cutting‑edge and in‑demand technologies for additive and hybrid manufacturing using robots
Applications
Tool-to-part and part-to-tool supportedTechnology highlight:
additive and hybrid
Cutting edge
high demanded technology for additive and hybrid manufacturing with robots
Ready to embark on your SprutCAM X journey?
Select your preferred path
Get a trial version
Download a free 30-day trial version of SprutCAM X or SprutCAM X Robot. Take online courses and get a certificate.
Request a quote
Find a local SprutCAM X dealer and get a quote for the turnkey solution.
