STEP SR220-3100
STEP SR220-3100 specs:
Type Industrial Robot
Brand STEP
Model SR220-3100
Axes 6
Payload 220 kg
Reach 3140 mm
Repeatability 0.1 mm
Weight 1345 kg
Start programming STEP SR220-3100
STEP SR220-3100 | SprutCAM X
STEP SR220-3100 description
Watch STEP SR220-3100 in 3D
STEP SR220-3100 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot STEP SR220-3100 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Robot welding, Pick and place.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how STEP SR220-3100 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
STEP SR220-3100 applications programmed with SprutCAM X Robot
How to start programming STEP SR220-3100 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including STEP. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the STEP SR220-3100, please contact the manufacturer or local supplier.
If you have questions about purchasing the STEP SR220-3100, please contact the manufacturer or local supplier.
