STEP SR12-1400
STEP SR12-1400 specs:
Type Industrial Robot
Brand STEP
Model SR12-1400
Axes 6
Payload 12 kg
Reach 1460 mm
Repeatability 0.03 mm
Weight
Start programming STEP SR12-1400
STEP SR12-1400 | SprutCAM X
STEP SR12-1400 description
Watch STEP SR12-1400 in 3D
STEP SR12-1400 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot STEP SR12-1400 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how STEP SR12-1400 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
STEP SR12-1400 applications programmed with SprutCAM X Robot
How to start programming STEP SR12-1400 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including STEP. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the STEP SR12-1400, please contact the manufacturer or local supplier.
If you have questions about purchasing the STEP SR12-1400, please contact the manufacturer or local supplier.
