ROKAE XB7
ROKAE XB7 specs:
| Type | Industrial Robot |
| Brand | ROKAE |
| Model | XB7 |
| Axes | 6 |
| Payload | 7 kg |
| Reach | 707 mm |
| Repeatability | 0.03 mm |
| Weight | 50 kg |
ROKAE XB7 description
ROKAE XB7 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ROKAE XB7 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Robot welding, Machine tending, Painting. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE XB7 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE XB7 applications programmed with SprutCAM X Robot
Spraying
How to start programming ROKAE XB7 with SprutCAM X Robot
