OMRON TM5M-700
OMRON TM5M-700 specs:
| Type | Cobot |
| Brand | OMRON |
| Model | TM5M-700 |
| Axes | 6 |
| Payload | 6 kg |
| Reach | 700 mm |
| Repeatability | 0.05 mm |
| Weight | 22.1 kg |
OMRON TM5M-700 description
OMRON TM5M-700 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot OMRON TM5M-700 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Pick and place, Assembly, Machine Tending, Robot welding, Trimming.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how OMRON TM5M-700 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
OMRON TM5M-700 applications programmed with SprutCAM X Robot
How to start programming OMRON TM5M-700 with SprutCAM X Robot
