OMRON RT6-2011124
OMRON RT6-2011124 specs:
Type Cobot
Brand OMRON
Model RT6-2011124
Axes 6
Payload
Reach
Repeatability
Weight
Start programming OMRON RT6-2011124
OMRON RT6-2011124 | SprutCAM X
OMRON RT6-2011124 description
Watch OMRON RT6-2011124 in 3D
OMRON RT6-2011124 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot OMRON RT6-2011124 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Robot welding, Pick and place, Assembly. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how OMRON RT6-2011124 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
OMRON RT6-2011124 applications programmed with SprutCAM X Robot
How to start programming OMRON RT6-2011124 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the OMRON RT6-2011124, please contact the manufacturer or local supplier.
If you have questions about purchasing the OMRON RT6-2011124, please contact the manufacturer or local supplier.
