KAWASAKI MXP360L-A
KAWASAKI MXP360L-A specs:
Type Industrial Robot
Brand KAWASAKI
Model MXP360L-A
Axes 7
Payload 360 kg
Reach 3234 mm
Repeatability 0.08 mm
Weight 1550 kg
Start programming KAWASAKI MXP360L-A
KAWASAKI MXP360L-A | SprutCAM X
KAWASAKI MXP360L-A description
Watch KAWASAKI MXP360L-A in 3D
KAWASAKI MXP360L-A applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot KAWASAKI MXP360L-A can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how KAWASAKI MXP360L-A can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KAWASAKI MXP360L-A applications programmed with SprutCAM X Robot
Polishing
How to start programming KAWASAKI MXP360L-A with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the KAWASAKI MXP360L-A, please contact the manufacturer or local supplier.
If you have questions about purchasing the KAWASAKI MXP360L-A, please contact the manufacturer or local supplier.
