JAKA C 7
JAKA C 7 specs:
Type Cobot
Brand JAKA
Model C 7
Axes 6
Payload 7 kg
Reach 819 mm
Repeatability 0.02 mm
Weight 22 kg
Start programming JAKA C 7
JAKA C 7 | SprutCAM X
JAKA C 7 description
Watch JAKA C 7 in 3D
JAKA C 7 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot JAKA C 7 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Pick and place, Assembly, Machine Tending.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how JAKA C 7 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
JAKA C 7 applications programmed with SprutCAM X Robot
How to start programming JAKA C 7 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including JAKA. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the JAKA C 7, please contact the manufacturer or local supplier.
If you have questions about purchasing the JAKA C 7, please contact the manufacturer or local supplier.
