HANS E05-Pro
HANS E05-Pro specs:
Type Cobot
Brand HANS
Model E05-Pro
Axes 6
Payload 5 kg
Reach 800 mm
Repeatability 0.03 mm
Weight 25 kg
Start programming HANS E05-Pro
HANS E05-Pro | SprutCAM X
HANS E05-Pro description
Watch HANS E05-Pro in 3D
HANS E05-Pro applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot HANS E05-Pro can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Assembly.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how HANS E05-Pro can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
HANS E05-Pro applications programmed with SprutCAM X Robot
How to start programming HANS E05-Pro with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including HANS. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the HANS E05-Pro, please contact the manufacturer or local supplier.
If you have questions about purchasing the HANS E05-Pro, please contact the manufacturer or local supplier.
