AUBO iS7
AUBO iS7 specs:
Type Cobot
Brand AUBO
Model iS7
Axes 6
Payload
Reach
Repeatability
Weight
Start programming AUBO iS7
AUBO iS7 | SprutCAM X
AUBO iS7 description
Watch AUBO iS7 in 3D
AUBO iS7 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot AUBO iS7 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Robot welding, Pick and place.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how AUBO iS7 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
AUBO iS7 applications programmed with SprutCAM X Robot
How to start programming AUBO iS7 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including AUBO. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the AUBO iS7, please contact the manufacturer or local supplier.
If you have questions about purchasing the AUBO iS7, please contact the manufacturer or local supplier.
