ROKAE xMate CR7
ROKAE xMate CR7 specs:
TypeCobot
BrandROKAE
ModelxMate CR7
Axes6
Payload7 kg
Reach988 mm
Repeatability0.02 mm
Weight27 kg
Start programming ROKAE xMate CR7
ROKAE xMate CR7 | SprutCAM X
ROKAE xMate CR7 description
Watch ROKAE xMate CR7 in 3D
ROKAE xMate CR7 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot ROKAE xMate CR7 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Additive manufacturing, Assembly, Dispensing. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE xMate CR7 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE xMate CR7 applications programmed with SprutCAM X Robot
Spraying
How to start programming ROKAE xMate CR7 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ROKAE xMate CR7, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE xMate CR7, please contact the manufacturer or local supplier.
