ROKAE xMate CR7-C
ROKAE xMate CR7-C specs:
Type Cobot
Brand ROKAE
Model xMate CR7-C
Axes 6
Payload 7 kg
Reach 988 mm
Repeatability 0.02 mm
Weight 25 kg
Start programming ROKAE xMate CR7-C
ROKAE xMate CR7-C | SprutCAM X
ROKAE xMate CR7-C description
Watch ROKAE xMate CR7-C in 3D
ROKAE xMate CR7-C applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot ROKAE xMate CR7-C can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Trimming, Machine tending, Welding. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE xMate CR7-C can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE xMate CR7-C applications programmed with SprutCAM X Robot
How to start programming ROKAE xMate CR7-C with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ROKAE xMate CR7-C, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE xMate CR7-C, please contact the manufacturer or local supplier.
