ROKAE xMate CR12-C
ROKAE xMate CR12-C specs:
Type Cobot
Brand ROKAE
Model xMate CR12-C
Axes 6
Payload 12 kg
Reach 1434 mm
Repeatability 0.03 mm
Weight 41 kg
Start programming ROKAE xMate CR12-C
ROKAE xMate CR12-C | SprutCAM X
ROKAE xMate CR12-C description
Watch ROKAE xMate CR12-C in 3D
ROKAE xMate CR12-C applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot ROKAE xMate CR12-C can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Spraying.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE xMate CR12-C can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE xMate CR12-C applications programmed with SprutCAM X Robot
Spraying
How to start programming ROKAE xMate CR12-C with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ROKAE xMate CR12-C, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE xMate CR12-C, please contact the manufacturer or local supplier.
