ROKAE XB7L
ROKAE XB7L specs:
TypeIndustrial Robot
BrandROKAE
ModelXB7L
Axes6
Payload7 kg
Reach906 mm
Repeatability0.03 mm
Weight52 kg
Start programming ROKAE XB7L
ROKAE XB7L | SprutCAM X
ROKAE XB7L description
Watch ROKAE XB7L in 3D
ROKAE XB7L applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ROKAE XB7L can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Trimming, Robot welding, Pick and place. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE XB7L can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE XB7L applications programmed with SprutCAM X Robot
How to start programming ROKAE XB7L with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ROKAE XB7L, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE XB7L, please contact the manufacturer or local supplier.
