ROKAE XB7
ROKAE XB7 specs:
Type Industrial Robot
Brand ROKAE
Model XB7
Axes 6
Payload 7 kg
Reach 707 mm
Repeatability 0.03 mm
Weight 50 kg
Start programming ROKAE XB7
ROKAE XB7 | SprutCAM X
ROKAE XB7 description
Watch ROKAE XB7 in 3D
ROKAE XB7 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ROKAE XB7 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Robot welding, Machine tending, Painting. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE XB7 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE XB7 applications programmed with SprutCAM X Robot
Spraying
How to start programming ROKAE XB7 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ROKAE XB7, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE XB7, please contact the manufacturer or local supplier.
