ROKAE XB4(XBC3)
ROKAE XB4(XBC3) specs:
TypeIndustrial Robot
BrandROKAE
ModelXB4(XBC3)
Axes6
Payload4 kg
Reach475 mm
Repeatability0.02 mm
Weight21 kg
Start programming ROKAE XB4(XBC3)
ROKAE XB4(XBC3) | SprutCAM X
ROKAE XB4(XBC3) description
Watch ROKAE XB4(XBC3) in 3D
ROKAE XB4(XBC3) applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ROKAE XB4(XBC3) can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Deburring, Polishing, Grinding. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE XB4(XBC3) can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE XB4(XBC3) applications programmed with SprutCAM X Robot
Polishing
How to start programming ROKAE XB4(XBC3) with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ROKAE XB4(XBC3), please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE XB4(XBC3), please contact the manufacturer or local supplier.
