ROKAE NB80-80_2.2
ROKAE NB80-80_2.2 specs:
TypeIndustrial Robot
BrandROKAE
ModelNB80-80_2.2
Axes6
Payload80 kg
Reach2200 mm
Repeatability0.06 mm
Weight635 kg
Start programming ROKAE NB80-80_2.2
ROKAE NB80-80_2.2 | SprutCAM X
ROKAE NB80-80_2.2 description
Watch ROKAE NB80-80_2.2 in 3D
ROKAE NB80-80_2.2 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ROKAE NB80-80_2.2 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how ROKAE NB80-80_2.2 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE NB80-80_2.2 applications programmed with SprutCAM X Robot
How to start programming ROKAE NB80-80_2.2 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ROKAE NB80-80_2.2, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE NB80-80_2.2, please contact the manufacturer or local supplier.
