ROKAE NB80-50_2.6
ROKAE NB80-50_2.6 specs:
Type Industrial Robot
Brand ROKAE
Model NB80-50_2.6
Axes 6
Payload 50 kg
Reach 2598 mm
Repeatability 0.08 mm
Weight 645 kg
Start programming ROKAE NB80-50_2.6
ROKAE NB80-50_2.6 | SprutCAM X
ROKAE NB80-50_2.6 description
Watch ROKAE NB80-50_2.6 in 3D
ROKAE NB80-50_2.6 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ROKAE NB80-50_2.6 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Trimming, Assembly, Machine Tending. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE NB80-50_2.6 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE NB80-50_2.6 applications programmed with SprutCAM X Robot
How to start programming ROKAE NB80-50_2.6 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ROKAE NB80-50_2.6, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE NB80-50_2.6, please contact the manufacturer or local supplier.
