ROKAE NB25-12/2.1
ROKAE NB25-12/2.1 specs:
Type Industrial Robot
Brand ROKAE
Model NB25-12/2.1
Axes 6
Payload 12 kg
Reach 2110 mm
Repeatability 0.05 mm
Weight 262 kg
Start programming ROKAE NB25-12/2.1
ROKAE NB25-12/2.1 | SprutCAM X
ROKAE NB25-12/2.1 description
Watch ROKAE NB25-12/2.1 in 3D
ROKAE NB25-12/2.1 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ROKAE NB25-12/2.1 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how ROKAE NB25-12/2.1 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE NB25-12/2.1 applications programmed with SprutCAM X Robot
How to start programming ROKAE NB25-12/2.1 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ROKAE NB25-12/2.1, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE NB25-12/2.1, please contact the manufacturer or local supplier.
