ROKAE NB220-150_3.2
ROKAE NB220-150_3.2 specs:
TypeIndustrial Robot
BrandROKAE
ModelNB220-150_3.2
Axes6
Payload150 kg
Reach3201 mm
Repeatability0.08 mm
Weight1165 kg
Start programming ROKAE NB220-150_3.2
ROKAE NB220-150_3.2 | SprutCAM X
ROKAE NB220-150_3.2 description
Watch ROKAE NB220-150_3.2 in 3D
ROKAE NB220-150_3.2 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ROKAE NB220-150_3.2 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how ROKAE NB220-150_3.2 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE NB220-150_3.2 applications programmed with SprutCAM X Robot
How to start programming ROKAE NB220-150_3.2 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ROKAE NB220-150_3.2, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE NB220-150_3.2, please contact the manufacturer or local supplier.
