[fusion_builder_container type=”flex” hundred_percent=”no” hundred_percent_height=”yes” hundred_percent_height_scroll=”no” align_content=”center” flex_align_items=”flex-start” flex_justify_content=”flex-start” flex_wrap=”wrap” hundred_percent_height_center_content=”yes” equal_height_columns=”no” container_tag=”div” hide_on_mobile=”small-visibility,medium-visibility,large-visibility” status=”published” spacing_medium=”” spacing_small=”” padding_dimensions_medium=”” padding_dimensions_small=”” border_sizes=”” border_style=”solid” box_shadow=”no” box_shadow_blur=”0″ box_shadow_spread=”0″ gradient_start_color=”” gradient_end_color=”” gradient_start_position=”0″ gradient_end_position=”100″ gradient_type=”linear” radial_direction=”center center” linear_angle=”180″ background_position=”center center” background_repeat=”no-repeat” background_custom_size=”” background_custom_size_medium=”” background_custom_size_small=”” fade=”no” background_parallax=”none” enable_mobile=”no” parallax_speed=”0.3″ background_blend_mode=”none” background_slider_position=”” background_slider_skip_lazy_loading=”no” background_slider_loop=”yes” background_slider_pause_on_hover=”no” background_slider_slideshow_speed=”5000″ background_slider_animation=”fade” background_slider_direction=”up” background_slider_animation_speed=”800″ video_aspect_ratio=”16:9″ video_loop=”yes” video_mute=”yes” pattern_bg=”none” pattern_custom_bg=”” pattern_bg_color=”” pattern_bg_style=”default” pattern_bg_opacity=”100″ pattern_bg_size=”” pattern_bg_blend_mode=”normal” mask_bg=”none” mask_custom_bg=”” mask_bg_color=”” mask_bg_accent_color=”” mask_bg_style=”default” mask_bg_opacity=”100″ mask_bg_transform=”left” mask_bg_blend_mode=”normal” render_logics=”” logics=”” absolute=”off” absolute_devices=”small,medium,large” sticky=”off” sticky_devices=”small-visibility,medium-visibility,large-visibility” sticky_transition_offset=”0″ scroll_offset=”0″ animation_direction=”left” animation_color=”” animation_speed=”0.3″ animation_delay=”0″ filter_hue=”0″ filter_saturation=”100″ filter_brightness=”100″ filter_contrast=”100″ filter_invert=”0″ filter_sepia=”0″ filter_opacity=”100″ filter_blur=”0″ filter_hue_hover=”0″ filter_saturation_hover=”100″ filter_brightness_hover=”100″ filter_contrast_hover=”100″ filter_invert_hover=”0″ filter_sepia_hover=”0″ filter_opacity_hover=”100″ filter_blur_hover=”0″][fusion_builder_row][fusion_builder_column type=”1_1″ align_self=”auto” content_layout=”column” align_content=”flex-start” valign_content=”flex-start” content_wrap=”wrap” center_content=”no” column_tag=”div” target=”_self” hide_on_mobile=”small-visibility,medium-visibility,large-visibility” sticky_display=”normal,sticky” type_medium=”” type_small=”” type=”1_1″ flex_grow_medium=”” flex_grow_small=”” flex_grow=”” flex_shrink_medium=”” flex_shrink_small=”” flex_shrink=”” order_medium=”0″ order_small=”0″ dimension_spacing_medium=”” dimension_spacing_small=”” dimension_spacing=”” dimension_margin_medium=”” dimension_margin_small=”” dimension_margin=”” padding_medium=”” padding_small=”” padding=”” hover_type=”none” border_sizes=”” border_style=”solid” border_radius=”” box_shadow=”no” dimension_box_shadow=”” box_shadow_blur=”0″ box_shadow_spread=”0″ background_type=”single” gradient_start_color=”” gradient_end_color=”” gradient_start_position=”0″ gradient_end_position=”100″ gradient_type=”linear” radial_direction=”center center” linear_angle=”180″ lazy_load=”avada” background_position=”left top” background_repeat=”no-repeat” background_custom_size=”” background_custom_size_medium=”” background_custom_size_small=”” background_blend_mode=”none” background_slider_position=”” background_slider_skip_lazy_loading=”no” background_slider_loop=”yes” background_slider_pause_on_hover=”no” background_slider_slideshow_speed=”5000″ background_slider_animation=”fade” background_slider_direction=”up” background_slider_animation_speed=”800″ render_logics=”” sticky=”off” sticky_devices=”small-visibility,medium-visibility,large-visibility” absolute=”off” absolute_props=”” filter_type=”regular” filter_hover_element=”self” filter_hue=”0″ filter_saturation=”100″ filter_brightness=”100″ filter_contrast=”100″ filter_invert=”0″ filter_sepia=”0″ filter_opacity=”100″ filter_blur=”0″ filter_hue_hover=”0″ filter_saturation_hover=”100″ filter_brightness_hover=”100″ filter_contrast_hover=”100″ filter_invert_hover=”0″ filter_sepia_hover=”0″ filter_opacity_hover=”100″ filter_blur_hover=”0″ transform_type=”regular” transform_hover_element=”self” transform_scale_x=”1″ transform_scale_y=”1″ transform_translate_x=”0″ transform_translate_y=”0″ transform_rotate=”0″ transform_skew_x=”0″ transform_skew_y=”0″ transform_scale_x_hover=”1″ transform_scale_y_hover=”1″ transform_translate_x_hover=”0″ transform_translate_y_hover=”0″ transform_rotate_hover=”0″ transform_skew_x_hover=”0″ transform_skew_y_hover=”0″ transform_origin=”” transition_duration=”300″ transition_easing=”ease” transition_custom_easing=”” motion_effects=”” scroll_motion_devices=”small-visibility,medium-visibility,large-visibility” animation_direction=”left” animation_color=”” animation_speed=”0.3″ animation_delay=”0″ min_height=”” last=”no” link=”” border_position=”all”][fusion_code]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[/fusion_code][/fusion_builder_column][/fusion_builder_row][/fusion_builder_container]
