ESTUN S3-60 Pro
ESTUN S3-60 Pro specs:
Type Cobot
Brand ESTUN
Model S3-60 Pro
Axes 6
Payload 3 kg
Reach 575.8 mm
Repeatability 0.03 mm
Weight 14 kg
Start programming ESTUN S3-60 Pro
ESTUN S3-60 Pro | SprutCAM X
ESTUN S3-60 Pro description
Watch ESTUN S3-60 Pro in 3D
ESTUN S3-60 Pro applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot ESTUN S3-60 Pro can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how ESTUN S3-60 Pro can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ESTUN S3-60 Pro applications programmed with SprutCAM X Robot
Polishing
How to start programming ESTUN S3-60 Pro with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including ESTUN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the ESTUN S3-60 Pro, please contact the manufacturer or local supplier.
If you have questions about purchasing the ESTUN S3-60 Pro, please contact the manufacturer or local supplier.
