Hermle C400 CNC machine and its Microdetails
How small parts can be made using SprutCAM and a Hermle C400 CNC machine? Sacher made a detail that was compared to a match. How do you like this size and detail?
The element for service instruments
Treatment: Hermle C 400
Material: PEEK
Created by: Sacher
See more original posts on Facebook
Find a solution for your CNC machine here.
About Hermle C400 CNC machine:
Many features combine to make for economical 5-axis / 5-side machining. The C 400 machining center is intended for high-performance, large-scale machining of workpieces to high accuracy and surface quality. The C 400 features a large working area with a small installation area. It can be ergonomically adapted to every machine operator – thus ensuring optimum ease of use.
SprutCAM
CAD/CAM solution
Install 30-day trial license. No functional limits
Download now
Explore CNC machines and industrial robot programming solutions
2.5x and 3x mill in CAM SprutCAM
4 axis milling in CAM SprutCAM
lathe in CAM SprutCAM
Mill-turn in CAM SprutCAM
Multi axis in CAM SprutCAM
High speed and adaptive processing in CAM SprutCAM
Swiss and MTM in CAM SprutCAM
5D and 6D cutting in CAM SprutCAM
Additive and hybrid processing in CAM SprutCAM
EDM in CAM SprutCAM
2D cutting processing in CAM SprutCAM
Got interested in SprutCAM?
Install SprutCAM
Download trial
Get SprutCAM
Find Reseller
