Rough test mill for robot
July 14, 2022
Test on real machines is very important for the correct work of SprutCAM X.
This is the test of rough milling operation from nioform.se
“So with a little help from Vitaly at SprutCAM the tool- and work object frames are now properly defined. Everything – including spatial arcs interpolation for any tool vector setup – is working correctly. Next step is to check accuracy for tiny as well as large parts!”
Our technical support team is always ready to help you with your projects.
