Lathe machining
September 5, 2022
Another interesting project with lathe, created bt roguetoolpath
“Some cam skill building with lathe module. Spending a little time setting up different lathe ops in different ways on a sample model. Hundreds of settings to understand, get tuned and working. Also job selection is not always a few easy clicks in the lathe module. Cam setup for a simple turners cube is little more work on a lathe then a mill. I find cam work to be a perishable skill that works best if you keep sharp.”
Find more projects created by our customers here.
