KUKA iiwa7 R800 - MF Touch pneumatisch
KUKA iiwa7 R800 - MF Touch pneumatisch specs:
Brand KUKA
Model iiwa7 R800 - MF Touch pneumatisch
Axes 7
Payload 7 kg
Reach 800 mm
Repeatability 0.1 mm
Weight 23.9 kg
Start programming KUKA iiwa7 R800 – MF Touch pneumatisch
KUKA iiwa7 R800 - MF Touch pneumatisch | SprutCAM X
KUKA iiwa7 R800 – MF Touch pneumatisch description
Watch KUKA iiwa7 R800 – MF Touch pneumatisch in 3D
KUKA iiwa7 R800 – MF Touch pneumatisch applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot KUKA iiwa7 R800 - MF Touch pneumatisch can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Assembly, Pick and place, Trimming, Machine Tending. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how KUKA iiwa7 R800 – MF Touch pneumatisch can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KUKA iiwa7 R800 – MF Touch pneumatisch applications programmed with SprutCAM X Robot
How to start programming KUKA iiwa7 R800 - MF Touch pneumatisch with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including KUKA. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the KUKA iiwa7 R800 – MF Touch pneumatisch, please contact the manufacturer or local supplier.
If you have questions about purchasing the KUKA iiwa7 R800 – MF Touch pneumatisch, please contact the manufacturer or local supplier.
