Demo of SprutCAM X Robot on Leanteс robot
31 března, 2023
SprutCAM X Robot can work with various robot arm manufacturers. Our partner from Vietnam SoftOne Solutions who tested SprutCAM X with the Leantec robot, found it to work perfectly. The Leantec robot is a 6-axis robot that has an arm length range of 600 mm to 3200 mm and a load capacity range of 4 kg to 300 kg.
You can see the result of the demo run of milling operation and simulation in SprutCAM X on the video
