Fanuc CRX 10iA
Fanuc CRX 10iA specs:
Type
Brand
Model
Payload
Reach
Repeatability
Weight
Start programming Fanuc CRX 10iA
Fanuc CRX 10iA | SprutCAM X
Fanuc CRX 10iA description
Watch Fanuc CRX 10iA in 3D
Fanuc CRX 10iA applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot Fanuc CRX 10iA can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how Fanuc CRX 10iA can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
Fanuc CRX 10iA applications programmed with SprutCAM X Robot
How to start programming Fanuc CRX 10iA with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including Fanuc. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the Fanuc CRX 10iA, please contact the manufacturer or local supplier.
If you have questions about purchasing the Fanuc CRX 10iA, please contact the manufacturer or local supplier.
