INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN
INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN specs:
Brand INOVANCE
Model 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN
Payload 10 kg
Reach 1422 mm
Repeatability 0.05 mm
Weight 130 kg
Start programming INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN
INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN | SprutCAM X
INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN description
Watch INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN in 3D
INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Polishing. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN applications programmed with SprutCAM X Robot
How to start programming INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including INOVANCE. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN, please contact the manufacturer or local supplier.
If you have questions about purchasing the INOVANCE 01741041-WXSTEP_B00(IR-R10-140S-INT-3D)-EN, please contact the manufacturer or local supplier.
