AUTONOX AT-00006-01
AUTONOX AT-00006-01 specs:
Brand AUTONOX
Model AT-00006-01
Payload 30 kg
Reach 2257 mm
Weight 417 kg
Start programming AUTONOX AT-00006-01
AUTONOX AT-00006-01 | SprutCAM X
AUTONOX AT-00006-01 description
Watch AUTONOX AT-00006-01 in 3D
AUTONOX AT-00006-01 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot AUTONOX AT-00006-01 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Robot welding, Assembly, Machine Tending.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how AUTONOX AT-00006-01 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
AUTONOX AT-00006-01 applications programmed with SprutCAM X Robot
How to start programming AUTONOX AT-00006-01 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including AUTONOX. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the AUTONOX AT-00006-01, please contact the manufacturer or local supplier.
If you have questions about purchasing the AUTONOX AT-00006-01, please contact the manufacturer or local supplier.
