TECHMAN TM5SX
TECHMAN TM5SX specs:
Type Cobot
Brand TECHMAN
Model TM5SX
Axes 6
Payload 5 kg
Reach 946 mm
Repeatability 0.03 mm
Weight 23.9 kg
Start programming TECHMAN TM5SX
TECHMAN TM5SX | SprutCAM X
TECHMAN TM5SX description
Watch TECHMAN TM5SX in 3D
TECHMAN TM5SX applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot TECHMAN TM5SX can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Pick and place.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how TECHMAN TM5SX can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
TECHMAN TM5SX applications programmed with SprutCAM X Robot
How to start programming TECHMAN TM5SX with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including TECHMAN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the TECHMAN TM5SX, please contact the manufacturer or local supplier.
If you have questions about purchasing the TECHMAN TM5SX, please contact the manufacturer or local supplier.
