STEP SR20-1700HT
STEP SR20-1700HT specs:
Type Industrial Robot
Brand STEP
Model SR20-1700HT
Axes 6
Payload 20 kg
Reach 1718 mm
Repeatability 0.05 mm
Weight 235 kg
Start programming STEP SR20-1700HT
STEP SR20-1700HT | SprutCAM X
STEP SR20-1700HT description
Watch STEP SR20-1700HT in 3D
STEP SR20-1700HT applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot STEP SR20-1700HT can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Deburring, Robot welding.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how STEP SR20-1700HT can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
STEP SR20-1700HT applications programmed with SprutCAM X Robot
How to start programming STEP SR20-1700HT with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including STEP. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the STEP SR20-1700HT, please contact the manufacturer or local supplier.
If you have questions about purchasing the STEP SR20-1700HT, please contact the manufacturer or local supplier.
