RAINBOW RB20-1900ES
RAINBOW RB20-1900ES specs:
Type Cobot
Brand RAINBOW
Model RB20-1900ES
Axes 6
Payload 20 kg
Reach 1900 mm
Repeatability 0.05 mm
Weight 75 kg
Start programming RAINBOW RB20-1900ES
RAINBOW RB20-1900ES | SprutCAM X
RAINBOW RB20-1900ES description
Watch RAINBOW RB20-1900ES in 3D
RAINBOW RB20-1900ES applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot RAINBOW RB20-1900ES can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Deburring, Assembly.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how RAINBOW RB20-1900ES can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
RAINBOW RB20-1900ES applications programmed with SprutCAM X Robot
How to start programming RAINBOW RB20-1900ES with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including RAINBOW. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the RAINBOW RB20-1900ES, please contact the manufacturer or local supplier.
If you have questions about purchasing the RAINBOW RB20-1900ES, please contact the manufacturer or local supplier.
