OMRON TM12
OMRON TM12 specs:
Type Cobot
Brand OMRON
Model TM12
Axes 6
Payload 12 kg
Reach 1300 mm
Repeatability 0.1 mm
Weight 33.3 kg
Start programming OMRON TM12
OMRON TM12 | SprutCAM X
OMRON TM12 description
Watch OMRON TM12 in 3D
OMRON TM12 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot OMRON TM12 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Pick and place, Machine Tending, Assembly, Dispensing, Deburring. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how OMRON TM12 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
OMRON TM12 applications programmed with SprutCAM X Robot
Spraying
How to start programming OMRON TM12 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the OMRON TM12, please contact the manufacturer or local supplier.
If you have questions about purchasing the OMRON TM12, please contact the manufacturer or local supplier.
