KUKA KR 800 R2800-2 F
KUKA KR 800 R2800-2 F specs:
Type Industrial Robot
Brand KUKA
Model KR 800 R2800-2 F
Axes 6
Payload 800 kg
Reach 2800 mm
Repeatability 0.08 mm
Weight 2400 kg
Start programming KUKA KR 800 R2800-2 F
KUKA KR 800 R2800-2 F | SprutCAM X
KUKA KR 800 R2800-2 F description
Watch KUKA KR 800 R2800-2 F in 3D
KUKA KR 800 R2800-2 F applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot KUKA KR 800 R2800-2 F can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Pick and place, Robot welding, Assembly, Multiaxis cutting. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how KUKA KR 800 R2800-2 F can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KUKA KR 800 R2800-2 F applications programmed with SprutCAM X Robot
How to start programming KUKA KR 800 R2800-2 F with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including KUKA. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the KUKA KR 800 R2800-2 F, please contact the manufacturer or local supplier.
If you have questions about purchasing the KUKA KR 800 R2800-2 F, please contact the manufacturer or local supplier.
