HSR JR618-2000
HSR JR618-2000 specs:
Type Industrial Robot
Brand HSR
Model JR618-2000
Axes 6
Payload 60 kg
Reach 2000 mm
Repeatability 0.06 mm
Weight 730 kg
Start programming HSR JR618-2000
HSR JR618-2000 | SprutCAM X
HSR JR618-2000 description
Watch HSR JR618-2000 in 3D
HSR JR618-2000 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot HSR JR618-2000 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how HSR JR618-2000 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
HSR JR618-2000 applications programmed with SprutCAM X Robot
How to start programming HSR JR618-2000 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including HSR. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the HSR JR618-2000, please contact the manufacturer or local supplier.
If you have questions about purchasing the HSR JR618-2000, please contact the manufacturer or local supplier.
