Fanuc R-2000iC-210F
Fanuc R-2000iC-210F specs:
Type | |
Brand | |
Model | |
Axes | |
Payload | |
Reach | |
Repeatability | |
Weight |
Fanuc R-2000iC-210F description
Fanuc R-2000iC-210F applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot Fanuc R-2000iC-210F can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how Fanuc R-2000iC-210F can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
Fanuc R-2000iC-210F applications programmed with SprutCAM X Robot
How to start programming Fanuc R-2000iC-210F with SprutCAM X Robot
