DOBOT CR7A
DOBOT CR7A specs:
| Type | Cobot |
| Brand | DOBOT |
| Model | CR7A |
| Axes | 6 |
| Payload | 7 kg |
| Reach | 990 mm |
| Repeatability | 0.02 mm |
| Weight | 24.5 kg |
DOBOT CR7A description
DOBOT CR7A applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot DOBOT CR7A can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Pick and place, Assembly, Machine Tending. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how DOBOT CR7A can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
DOBOT CR7A applications programmed with SprutCAM X Robot
How to start programming DOBOT CR7A with SprutCAM X Robot
