DOBOT CR7
DOBOT CR7 specs:
Type Cobot
Brand DOBOT
Model CR7
Axes 6
Payload 7 kg
Reach 990 mm
Repeatability 0.02 mm
Weight 24.5 kg
Start programming DOBOT CR7
DOBOT CR7 | SprutCAM X
DOBOT CR7 description
Watch DOBOT CR7 in 3D
DOBOT CR7 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot DOBOT CR7 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Pick and place, Assembly, Machine Tending. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how DOBOT CR7 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
DOBOT CR7 applications programmed with SprutCAM X Robot
How to start programming DOBOT CR7 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including DOBOT. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the DOBOT CR7, please contact the manufacturer or local supplier.
If you have questions about purchasing the DOBOT CR7, please contact the manufacturer or local supplier.
